MINI WAGON RE DO
I wonder if ther's a way, if you raised, or lowered the mount point and added Heim joints...Hmmm. I can see where they would bind up in the lowered position. There's gotta be a way-
yeah there is a way to do it. the sway bar will clear, just never got sway bar holes in the lower tubular control arms.
I just put my front end back together. I shortened my sway bar end links 2.5" but it seems to hold the car up about 1" from laying out. I'll probably take it out for now. I did have to lose my heater box 😢
yeah that will happen when you want to run 20" wheels and slam it. I am going to install a hot rod a/c/ heat system this spring. everything will be in the dash with just the 4 lines coming out of a bulkhead.
A front sway bar will depend on what you are building your car for. my wagon i wanted to go as low as I could. The next car I do will be on air but more ProTour set up. might not touch the ground be will handle like a son of a b*tch 😀
