Couple of other tips / suggestions:
If the engine is on the stand:
May be a good time to prime it - can get kind of tight if trying to prime once it's in the engine compartment. If it's a SBC you can use an old distributor drive for this, or get a tool - they're kind of cheap $$ You will start to feel drag on the drill was pressure starts to build - and as stated before, have the covers off to make sure the oil is getting to the rockers.
Would suggest pulling the distributor (or at least the cap). This way will not have to worry about banging it against the firewall and breaking it. Just remember to make the markings before pulling it so you can reinstall it correctly
Once in the car:
To the board: should break-in additive be added to the oil before starting?
Take your time dropping the motor in and wiring / plumbing everything up or you may give a new meaning to "Fire it up"
If you're doing headers may want to drop them in first and bungy them out the way
Have at least one buddy (preferrably two) looking under the hood while your cranking / starting the engine. One can hold the light to check for leaks, the other the extinguisher.
Do have a box fan at least in front to blow air across
Don't be surprised if a hose clamp or something comes loose, even after re-checking everything before start-up
After break-in and oil drain check the oil for particles - may be a good idea to cut the filter open too - and use a decent filter!!
Make sure the plug wires (any wires really) are as far away from the exhaust, intake, as possible.
Make sure timing is on or as close as possible
to the board - what's the thought about antifreeze in terms of mix, drainage after break-in?
Just my thoughts
Once in the car:
Just my thoughts
