Monte Carlo Dash Plate With Raised SS
matteo650
107
has any buddy installed Monte Carlo Dash Plate With Raised SS from from custom monte ss parts? just got mine in the mail
thanks
this? Had mine for a few years now and have other parts from them. One part was 4 years old and still looks like the day I got it..
You will need to trim the hole opening that holds the plastic part for the ac. I trimmed too much in this pic. I hole saw will do the trick.. This is if you have the tripple pod like mine. Not sure on the standard no pod setup
Elco Warren 8)
80z :twisted:
Elco Warren 8)
80z :twisted:
how did u pop out the old one? is it bolted in? and do u have to drill holes for the new one?
I gently pried on the outer edge of the factory plaque until the clips popped out. The new plaque has 4 threaded studs that line up perfectly with the factory holes in the dash. You should have 4 wing nut's and 4 round washers. I had some larger washers from the inner fender well area and used those in addition to the 4 supplied. I removed to glove box to be able to reach up inside and thread the wingnuts.. Really simple to do. No drilling required. Only cutting done was in the area shown in my last pic. I did that cuz the last gauge had clearance issues. Dual gauge setup and the no gauge style won't require the cutout. Gently pull the other one off, remove your glove box, line the studs up with the factory holes/slots and push the plaque in. The slots allow for you to center the plaque up. Reach up behind the dash thru the glove box area and feel Around for the plaques studs. Washers and then screw on the wing nuts. Now I have wiring running along behind the dash, so I unhook the battery to be safe. You won't be able to see and will have to feel around.. I may have a few pics of the factory clips and a photo or 2 of me installing the plaque. I'll look for it and post.. Good luck!
Elco Warren
Elco Warren
Hey dude, I just got a 87 ss monte carlo. Man your interior is tight!. I hope you dont mind, but im gonna model mine after yours. How man guages are you running?
Where did yu get the guage cluster from?
Thanks!! I sprayed it all with some SEM interior paint so I could have an idea of what things will look like once it's all stitched up by a pro. All gauges were purchased from dakotadigital.com. I'm running (10) 2 1/16" gauges, (2) auto meter gauges in the bread box area, and the main instrument cluster is dakota digital. I've been a big fan of Dakota digital for years. Never had a single issue with em. My Elco, SS and Malibu run em.. Thanks for the compliment!
Elco Warren 8)
80z :twisted:
thanks alot man
Elco Warren
