Would the monte ss cooling duct that goes in front of the radiator to the nose work on my cutlass. Would it increase cooling and has anyone done it and if so what mods did you have to do
I'd imagine the Monte grille has to be bigger than the euro cutlass one, even after accounting for the two tiny bumper holes. Has me curious to measure the two someday now that you get me thinking about it, doesn't it?What year cutlass?
The only reason for that piece was the tiny Monte grill. And for God’s sake, don’t stuff anything extra in front of the radiator with that thing. Best thing I ever did for cooling was taking that thing off and installing a chin spoiler.
Are you having a cooling system problem?
The only thing the GN has, and, the reason for it is the 1986/1987 turbocharged cars needed an inlet scoop to force air for the intercooler to work to cool the air charge for the turbo application. Other than that, 84/85 cars didn't get it.No i have no cooling problems. Just thought gm put these on the "performance" models for a reason.
Since the ss and grand national both have something similar i wondered if it would do anything on a 84 cutlass. I never really thought about the ss nose not having a regular grill for airflow. Where my car is all open
I had never seen one of these until this weekend and started googling it trying to learn its purpose
Not trying to highjack this thread but I’ll ask anyway; How bad were your cooling issues when you had something in front of the radiator?What year cutlass?
Why exactly did you put in there.Not trying to highjack this thread but I’ll ask anyway; How bad were your cooling issues when you had something in front of the radiator?
The reason I ask is I stuffed a sizeable transmission cooler in there.
Thought it was a good spot for it, it’s in direct airflow at speed, at less risk of damage from debris, and I just typically put coolers in front of the radiator, call it a bad habit.Why exactly did you put in there.
I dropped IAT’s 30-40 degrees when I removed the duct and factory core support.
That setup, I believe, had a lot of factory engineering to cool a 305 with a condenser and radiator in there. The front of my intercooler was 5-6” in front of the radiator. At the time I was making triple the HP of the original 305……..so maybe I should hold back on my comments haha.
I’d say don’t make a lot of modifications (shrug).
