I never use a spring compressor:
Unbolt the lower A-arm.
Install spring.
Attach the shock top/bottom.
Put jack under LCA at spring pocket.
Jack up.
Attach spindle to upper and lower balljoints loosely.
Keep jacking up and use large screwdriver to line up LCA bolt holes.
Install LCA bolts.
Tighten all bolts with weight on the tires.
This is basically the method outlined in the factory service manual. Spring is captured by the shock the entire time, so no danger that is present with compressors.
Install spring.
Jack up.
Install LCA bolts.
