Moog Springs Made of Gold
Jegs says they’re for 68-72 mid-sized even station wagons. Wouldn’t as bought raise the rear?
It's a different car so I go by the specs,
the highest spring rate for a G body has a .590 diameter, load height 10.25 with the spring forced installed height is 741 lbs
A body spring is rated 15 lbs higher, has a .580 diameter, load height 8.50 with the spring forced installed height is 738 lbs
so the A body spring with a similar weight for the spring forced installed height should drop the rear of G body by 1.75"
  • Informative
Reactions: fleming442
I keep forgetting you are in The Great White North.
I keep hearing that but I'm not so sure where they came up with great, this is our leader......:wtf:
iu
Reactions: olds307 and 403
iu
See we have a different kind of idiot running our country. Your guy isn't PC at all, our guy is the other extreme.
