More doorlock problems
rogus
448
180
I've replaced the the door lock actuators, the circut breaker, the door lock relay, switches...and all I get is a click when I press the switch...but only when I use the drivers side switch...I get no click or anything else from the passenger door switch. I used a voltmeter on the two wires that connect to actuator and meaured using a clean spot on the door panel as a ground.
Not sure what else to check to correct this. Anybody have any ideas?
