HDFXR1991 said:Good luck and still take the picture of the mud.
8)
Thanks and I will.
8)
CHRIS.O said:Your chevy rockers ARE NOT TORQUED like an olds. You tighten to take lash out. I don't have time at this moment to tell ya how to do it, just wanted to save you from messing sh*t up. Check on google, bunch of how to's on lashing valves. If you don't understand I'll be logged on later and can probably help.
HDFXR1991 said:DOH.... sorry David. I thought you had an Olds motor. My bad.
Thanks Chris for the save.
I'll go sit on the naughty chair now.
bill said:If im not mistaken, low oil pressure will kill the electrical signal to the engine to prevent massive damage. If you engine has oil pressure issues, due to sludge or clogged passages or a weak oil pump, the engine will lose pressure when you come to a stop as the rpms drop. I could be wrong about this, so somebody correct me if I am. Also, I had issues with my th200m torque converter not unlocking as I came to a stop, and it cause the engine to die sometimes at a light/sign. Good luck David!
CHRIS.O said:I highly doubt you have any of the original stuff from your old 3.8 to your 350 chevy so I'm gonna guess your oil level isn't a problem. Did you get your choke working right? If you have loose rockers that means a cylinder isn't going to be working correctly. Valves will not be opening as much as they are supposed to or in some cases not at all. You said you saw a couple loose ones. Did you lash them or someone else? Were they lashed at all?
