Im trying to get the small block back in my g body. Im using Energy Suspension motor mounts. The right side bracket that came on my block originally had a "captured" or "caged" nut so you wouldnt have a hard time getting it on with the fuel pump on. Me like an idiot cut that off because I wanted to use an electric pump. Now that Im using a mechanical pump I picked up another bracket at the local yard that had the "caged" nut. The problem is the nut is 7/16 and a 7/16 bolt is on the small side for the hole through the Energy mount. Its also small for the hole in the block bracket. Anyone know if GM made a metric setup like that ? A 1/2 bolt looks good in the bracket but it wont go through the Energy mount unless I drill the hole out. This makes me think its a metric bolt one size larger than 7/16. If GM had a metric bracket like that what cars would have it ? Thanks
