CUTLASS Motor mount help
REDWOOD
11
9
Need a Lil help trying to put olds 68 445 in 84 cutlass supreme I have no frame side of the motor mounts and can't seem to locate a correct set anywhere. I'm at a stand still till I fig this out but of course I have other things to work on in the mean time but all help would greatly be appreciated
oldsmobile joe
2,067
3,053
mpls
What engine was in your 84 cutlass?
85ss/85gn
292
258
beaver dam,wi
I have the correct bolds v8 motor mounts if needed
8,832
7,793
If the 307 frame mounts are in the car, All RWD Oldsmobile V8 from 1973 to 1990 use the same mounts and will work on your 455. If you buy the Anchor replacement mounts, which nearly everyone sells, many don't fit. It might take multiple sets to get good ones. Also you will need a cowl or W25 style hood to fit the 455 with that Performer intake. Also with added deck height and your tall valve covers it will hit the A/C box. It may be tight against the brake booster as well. Good luck, the style track looks good.
REDWOOD
11
9
No they weren't in it anymore but ordered set from oldsparts.com last night so hopefully they work. sh*t was wondering about all those exact issues. All the asking around I have done everyone is saying bot it will all work with no issues and all 3 are gonna give me issues to work out had go tall due to roller rockers. Thanks for help and compliments been long time coming trying not cut corners on it
8,260
17,789
RH/LH = 559271/559272 are the GM part numbers for the frame mounts, should you be able to find a new set somewhere.
8,260
17,789
I have no idea where you'd find them. They've been discontinued for quite a while now.
