Mounting bucket seats
Hubb79
8
I just grabbed a set of monte carlo set of seats lets say between the years of 04-08 and was wondering how to mount the seats to the track before mounting to the floor, what size nuts and bolts should be used.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
The stock seats had M8 threads in the frames under the upholstery. The seat brackets bolted to the bottom at the four corners. You will likely be best off using Gbody seat brackets and fabbing adapter plates for the four corners if they don't match. Interested to see your problem and your solution.
