So i want to install a MSD ignition box, I already have a MSD distributor. What else is needed, and what ignition box do i need. I really don't care about rev limiters, i just want the best performance. Help me out.
You will need a spare one.They are not reliable.82bonne said:So i want to install a MSD ignition box, I already have a MSD distributor. What else is needed, and what ignition box do i need. I really don't care about rev limiters, i just want the best performance. Help me out.
Phoenyx said:What kind of distributor do you have? Is it already set up for an MSD box, or does it have a module in it? If it has a module, just stick with that and forget the box.
Phoenyx said:What kind of distributor do you have? Is it already set up for an MSD box, or does it have a module in it? If it has a module, just stick with that and forget the box. It will be better than stock, it'll give your engine all the spark it need, and will be a lot more reliable.
I put one in a street car a few years ago. Ran it for 2 years, summer and winter. Didn't have any problem with it. But for the cost and hassle of installing it, I can say it wasn't worth it. Yes I noticed a very slight mileage gain, and it ran smoother. But couldn't feel any real difference in power. Also, I have changed out many 20+ year old stock modules for cheap new factory replacements. And they gave the same effect as putting the 6-AL did.
But if you have one of those MSD distributors that's designed for a box. Then all you really need is to buy the box and a coil. But I would keep your stock distributor and some tools in your trunk if you go this route. Just in case it craps out.
