My $60 buck pick up
youngdeezy said:
V, i didnt know this was going to be the start of your build thread otherwise i would have dropped a few more comments. i just covered everything agin from page 1 to the end. so its going to be a black and purple monster....well im good with that as long as you dont put barney on your doors :rofl: i know you have kids haha.
:rofl: :rofl: :rofl: Nawl I'm cool on the Barney pics LMAO!!! I tore it down, found out my block was cracked, bought another engine, and now I'm getting everything back together. I'll probably have some new pics up later tonight!
sup bruh hows things going with the car
Wow! Great thread! You got a super deal for $60. Here is mine when I first got it. I got it for $100 back in '04 from this guy who seemed to not be havin a good day at the time.
^^^ good thing was that mine had a 79 H/O Dual Gate shifter sittin in there already. :shock:
Veltboy618 said:
redboy504 said:
Keep up the GREAT work! Its lookin good. Dont worry about using second hand parts. Nobody will be able to tell. You got that engine lookin like new. I can't wait to see the finished product. Let me know if I can help with anything.
Thanks! Everything was going good until I got my own garage & I started tearing it all the way apart lol. Its in the garage on jackstands & I'm about to take the engine & trans back out & do a little surgery. I really want to pull the body off the frame & build it all the way back up but that will take up too much time & I'm trying to ride this summer. I'm not worried about putting used parts on the car as long as they work good. I love finding used parts because that's one less thing I have to buy new & more money going to other parts of my build. Wish I could afford to buy everything new though...
I know it has been a while since I updated this thread but here is how shes looking now. Once we moved into our new house I pulled it into the garage & started tearing apart to do a frame off build because that's what I really wanted in the first place.
I removed the ignition switch cut off the spot where it was & fiberglassed/smoothed it out since I'm going push button start & will not need it anymore
I tore it all the way apart
Bought this engine & kicked the other one to the curb. I may use it on another build if I dont get spoiled with the LS engines lol. I switched the intake & the front end to the car set up.
I threw the frame on my work truck & took it to get notched for my wheels, the LS1 oil pan & the low mount A/C compressor
I tried to clean up the frame myself but I was too much. I couldnt hit all of those hard to reach spots so I threw it back on the truck & dropped it off to the blaster. They will take care of it for me!
While the frame was gone that day, I took the belly down to metal, sprayed a couple coats of Chassis Saver on it then added some undercoating for additional protection.
Once i picked it up from the blaster I hit the fresh metal with a couple coats of Chassis Saver, painted up my engine block, control arms, trailing arms, spindles & calipers.
Test fitting the rear end with wheels & doing some measuring
I swapped the originals for the Blazer spindles to mount my Corvette brakes up front. I purchased some brackets & made a few mods to get another set of front C5 Vette calipers on the rear. I could have purchased an aftermarket kit but I wanted to do something a little different. I also added the drilled/slotted rotors.
Patiently waiting...
Her she is with the engine & trans mounted. The crossmember is only there temporarily & that rear end is not the one I'm using
Thats all I have for now. Hope you guys enjoy the pics!!!
finally caught the whole thread, im following this build on IG so cant see the whole build from the beginning..
Nice build btw keep the updates comin
