My 83 Grand prix. 5.0l, Auto.
yeah. I still say 5 1/4's in the rear sides but either way it sounds like you know what your doin. Your fronts, by the way will sound insane.
I just hope i can get some kicks fiberglassed up. I cut my baffles for them today.
Just time to get my stock kicks back in place, And start glassing!
Q Forms makes some too but if you know how to make your own you can probably do a better job anyway. I wasn't especially impressed with theres.
I aint paying $180 for a set of kicks, When making them would inspire me to make some 1 off peices for the rest of my car. I did have someone who had a set in storage, That i was gonna buy. They never got back with me tho :[
I decided id go out, And cut the remainder of my sub hole's out, When i got a tad bit carried away. Next thing you know i got a circular saw in my hand. And am ripping upo the 4x8 sheet.
2 hours ago, I started on this:
I already had it drawn out on the board, But i cut, Clamped, Predrilled, unclamped, Glued, Reclamped, Screwed it all together in a lil over 2 hours. Seem's came out nice, However ill be sanding about a 1/16" off of one side. Dunno if it was my measuring, or cut, But theres one corner that sticks out past square. Shouldnt be too hard to get sanded down.
As far as stacking the amp's, Im real concerned about the heat. Not to mention i like my stuff Symetrical, So i think im gonna go with one on each side.. Depending on what kinda room i can muster up. Either way, The box MUST be in the middle, Due to the trunk hinge lumps in the trunk lid.
Comparing the size of this box [2cuft^3 per chamber], There is NO WAY the last box was anywhere near the 2.5-3cuft^3 the shop told me it was. I feel Jipped, But the box is long gone, As well as subs, So no complaints here.
Your car is sweeet 😀 you should do a fiberglass enclosure just a thought
Gotta get the Kick panel's, And Rear side panel's done first. Its been kinda cold, and im waiting on more money for misc. wiring componets.
Wow i havent updated this in a while. Lets see where we shall start.
Ordered my ID oem's for the rear side panel's. They will be ran @ 2 ohm's with the front componets to the 4002.
Mid's and high's, Oh my!
Decided to go with Doorpods, instead of kick panel's. Got started on them:
Also started fiberglassing my tweeter cups into my A pillar panel's:
(These are currently in the garage curing.)
Fiberglass fabrication is about half way done, I still have to make a pod for my volt meter, As well as panels for my Image dynamics OEM 6.5"s that are going in the arm rests in the back seat, Then onto body filler / sanding / grinding.
Looks like you know a thing or two about audio :lol:
Once I get ready to put a (mild) system in mine, we will be in touch lol.
And car/ work looks great!
