Yeah, I did, but I only lifted it up a few inches. I de-rusted it under the bushings and painted it with rust inhibiting paint where necessary. I used a engine hoist hooked to the trunk latch to do the lift-in retrospect, not the smartest thing to do. This allowed access to all but the front two bushings and they were used to keep alignment.I used Energy Suspension poly bushings when I did it. I could have done it differently,but pulling the body a few inches off the frame took very little effort ( under an hour). I wanted a factory fuel line and all of the factory line clips from a sbc G body, and this was the easiest way to do it. I also removed the body from the donor car ( Grand Prix) in the junkyard using a chain fall hoist that they supply for pulling engines. All in all it was a $10 solution to the problem of the line with $80 thrown in to replace the rotten rubber bushings. I also realigned the body over the frame as it was offset 1/4 in to the passenger's side from the factory and the realignment made front tire clearance better.
