Bowiemontecarlo86 said:The cars coming along I see nice job on the bondo work.
Thank you, I'm ready to start of the motor but Olds are high to build so i'm working on it very slow.
TeezySupreme said:Lol, The bolts are to long and it has it leaning like that after i get the machine work done i have to get shorter bolts but it's being held up pretty good i'm just being lazy.
1983regal said:TeezySupreme said:Lol, The bolts are to long and it has it leaning like that after i get the machine work done i have to get shorter bolts but it's being held up pretty good i'm just being lazy.
Looks like you installed the upper part of the engine stand backwards, the hole for the part that bolts to the block should be at an angle. The angle should be angled up, yours looks to be angling down. I think if you turn the upper part around it will sit on there alot better. My big block leans down but not that much. Was trying to find a picture to show what I mean but was unable to find a side view of a stand.
finman04 said:Car is really coming along great, front bondo job looks good. I feel your pain on the olds rebuild also, cant beleive in these prices on olds motors. Great job!!
olds307 and 403 said:What was wrong with the #8 heads? They are good castings, the 3A have known cracking issues and flow even less than the #8 heads. What piston's, cam and head gaskets?
olds307 and 403 said:At least you will be around 8 to 1 with thick head gaskets and stock pistons. Stock cam? It will be a nice upgrade over the 305, at any rate.
