There are only really two types of pontiac V8s, small journal, and large journal. The Large Journal engines are the 421, 428, and the 455. Everything else (287, 317, 347, 370, 389, 195 4cyl, 326, 400, 350, the experimental 303, the 301, and the 265 [last pontiac put in a g body iirc]) are the small journal engines. Do you know anything about the guts? Cam? Compression? If you ever want a decent carb, get a quadrajet. BUT, be warned. The dual pattern aluminum edelbrock pontiac intakes (or at least all that I've seen) need to be clearances for a quadrajet to work as the freakin rear of the intake prevents the rear throttle blades from opening. In the meantime, or at least once it gets road worth, just keep pumping 93 in it. Last thing you want is for it to detonate itself to death. And NEVER. EVER. Put slicks or any sticky tire on that rear end. Traction and power is the enemy of the 7.5. Quick way to tell if it's a Th200r4 or a Th350 or whatever, Th200r4 has 4 forward gears. 1, 2, D/3, and OD/4. All others that came factory in g bodies (I think the 4 door cars like caprices and Delta 88s got the 700r4 iirc) were 3 speeds.
