I finally got things caught up enough to get back getting the lineshaft up. I had a couple of offers for help on getting the thing up in the air, but in the end schedules didn’t work out and I put it in myself. In spite of having to rearrange the shop and all the trips up and down the ladder, it was worth the effort.
The old adage we use when building cars that “it will take twice as long and cost twice as much as you expect” applied equally well to this little project. I thought I had majority of the stuff collected when I had the shaft, pulleys, bearings and belt gathered. By the time it was in the air and turning I had gone thru 60 feet of angle iron, 35 feet of flat stock and 40 feet of lumber, not counting copper tubing, fittings, wire etc.
The jackshaft and belt tensioner was pretty straight forward, but I had to build the exhaust twice. The first attempt I used 1 ¾” exhaust pipe and it caused the engine to load up badly. For the second attempt I used 2 1/2” pipe I had laying around, which worked out great. You might have noticed the 1” nipple and pipe cap at the 90 degree bend. I put that in so I could see and hear the exhaust when I fine tune the mixture on the carburator.
The Motsinger Autosparker (DC generator) draws a surprising amount of power. By turning the governor spring almost all the way in I can get a bit more than 12 volts out of it. I dialed it back to around 6 volts though so it not working all that hard. I also built a handle with a wedge on the end so I can disengage it completely from the pulley if I don’t want to run it at all. I put a 6V light in the old railroad lantern and also wired up a goose neck work light that can be used with either the grinder or drill.
The grinder was pretty straight forward. I did built a movable belt guide to slide the belt from the loose to tight pulley rather than just use a stick as was common when these were in general use.
The compressor is the newest piece of equipment, it’s only about 50 years old. Rather than belt it directly to the line shaft, the power goes thru a smaller belt and pulley setup and is activated by applying a belt tensioner. The adjustable pop off valve is set to 50 PSI and once the pressure is achieved it can be shut down by manually by releasing the belt tensioner. An old 30 pound Freon tank is used as pressure tank.
The post drill had also been set up for a V Belt and is activated by a spring loaded belt tensioner. I used a countershaft similar to the one on the compressor and it’s also activated by a spring loaded tensioner pulley. On the drill it allows the pulleys to be changed easily to change the speed. Spindle speed is currently about 140 RPM which is slow enough to engage the auto feed (which I really don’t use when I’m actually drilling anything but it is neat to watch work occasionally). I’ve drilled a few ½” holes on some 3/8 flat stock and the drill barely loads the engine.
I didn’t want to have to loosen the lineshaft (and realign it) every time I needed change a V belt, so I bit the bullet and ordered some Flexco V Belt splices. They work well but are very expensive.
Here is a link to the shaft working, you might want to turn the volume down a bit. The actual noise level when the line shaft is running is really quite reasonable by the way.
http://www.youtube.com/watch?v=wwk4niUu ... e=youtu.be
Enjoy.
