need bolts for hub to spindle
I will have what was "missing" from shipment,as I know I included a full hardware set-up with all other components I shipped to you.was the box damaged? Did you except it with visible damage? Nehoo.im busy here in standing rock(dakotas) handling a probate for my cousin as well as co.ing to an agreement on so.e easements the gov wants to run through portions of my land.i will relay this message for replacement bolt set-up for your brake set-up .by the end of the week.
Reactions: pontiacgp
Holy crap go to a hardware store......problem solved
Reactions: fleming442
No the boxes weren’t damaged. Those 6 bolts were not in any of the boxes. There were 4 front caliper mounting bolts, and 8 rear bracket bolts with nuts. And the 2 store packets of misc. hardware.
So we need 4 pab to spindle bolts,and 6 hub to spindle bolts correct?
Only the 6 , hub to spindle
I got the front brakes installed fine, go to start the rear ones after buying all new ceramic pads for a Blazer. They’re to big. What are these POR> calipers. I can’t find any info on them
