Need drum brake diagram
stomis
403
35
Brick NJ
www.billybobsfastcars.com
For our cars. My rear is an 8.5 but I believe its the same setup as a 7.5. I didnt take them apart and alas drums are my weak point. Usually I leave on together to use as reference but no dice since I pulled my entire rear.
lil help?
if you're changing the brake cylinder you may want to consider an S10 non power brake cylinder as it has a larger piston which increases the pressure to the shoes giving you better rear braking. Some people also put on two primary shoes on each side...
