Need Help Exhaust Headers AIR
drb930
48
7
8
Los Angeles
357 SBC, AFR 195 street eliminators, LPE 219,219 / 560,560, 10.5 to 1. Lunani forged steel crank, pink rods. LPE injection with 30lb injectors.
Also ANGLE PLUG HEADS!
Forgot G-BODY EL CAMINO!!!!!!!!!!
Questions-
Is 13/4 too big or should i go for 15/8?
Does any header manufacture make a long tube header with AIR fittings, i cant find one.
Where can i buy the AIR Fittings
I have a set of Doug Thorley TH 375-C 15/8 Y type header, should i just modify them?
HELP????????????????
Thanks,
Dave
megaladon6
4,006
15
Danbury, CT
i know that summit has AIR tubes that can be welded to the headers. you obviously have to drill holes for them but i think thats it. curious: why do you want air tubes?
drb930
48
7
8
Los Angeles
I live in California!
California!
megaladon6
4,006
15
Danbury, CT
if the car is 25 years old i believe you can get away without them. i know you can here. (new york supposedly copies cali law on this)
Monte SS 383
26
Altoona PA
It depends on if you want bolt on or to fabricate it yourself
Edelbrock makes a set for about $450
4 bolt cat ceramic coated 68792 and reg paint 68793
slip on cat ceramic 68792 and reg paint 68783
