So I took my 86 Cutlass Salon to the mechanic's yesterday because its been running really rough since the cold weather started in. Car/motor has 82k on the 307 and the previous owner removed the A.I.R./smog stuff. So after the mechanic looked it over, he determined that I probably have a few vaccuum leaks and he noticed that the choke wasn't functioning properly and that someone took a piece of wood and jammed it in the linkage on the passenger side of the carb to hold it open all the time. He recommended that I replace/rebuild the carb, replace all the vaccuum lines and re-install all new smog componants. He admitted that he isn't an expert on older cars but was convinced that this would solve my rough starting/idling and bogging down under aggressive acceleration.
Would anyone else concur with this diagnosis?
BTW, the previous owner didn't remove the AIR tubes from the motor, just cut them and TIG'd them closed. He probably couldn't get them out
