I've narrowed my gasket choice to either Remflex or Mr. Gasket Ultra seal...or possibly Earl's
True or False, Ultra Seals can be trimmed to match ports without damaging the gasket.
On Remflex...I've seen ratings at 50/50. People rate them as POS/Awesome. For those with experience using them, do you think that the bad experiences are a direct result of not following the directions and specs? I've also read about how fragile these are. True or False, can Remflex be trimmed to match ports without damaging the gasket.
Who's using Earl's, any leaks?
Also, I've been told that cutting the gasket into three pieces, like so...
will provide a superior seal. It sounds logical; less surface area=less imperfections...but is it legitimate? Anyone ever done this?
As for hardware, what exact type of lock washers are being used by you guys? I'm considering getting some total locs but if I can just get some lock washers from the hardware store that would be better (cheaper) for now. I think I've seen those types of washers at ACE before, but now I can't find them. Anyone know what their technical name is?
Thanks in advance
![cut_gasket.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi1016.photobucket.com%2Falbums%2Faf288%2Fmoose_316%2Fcut_gasket.jpg&hash=73d78425dae98b71a5c915eef0e34617)
Thanks in advance
