need some help wire problem
86 maroon gp 2+2
269
31
Oxford, MI
so I found this connector lose in the engine bay and was wondering if any of you could help me out, its a 305 motor and its the bright green connector in pictures. I have a wiring diagram but I'm confused as to what goes where, I find myself looking at a light blue wire going into a dark green wire :wtf:
that wire is so you can use a dwell meter to dial in the carb. It doesn't connect to anything in the engine bay. Just hook up your dwell meter to it while on the 6 cyl and see if it is running around 3o degrees. I just put mine under the wires and lines while i am not using it. I hope this helps.
That green connector doesn't connect to anything its for testing purpose.
X2
