I've been messing with cars for a minute, and have never seen a broken chain. Stretched? Yes. Broken? No. What's the history? Brand? Circumstances during breakage?The evidence of broken chains doesn't interest you?
I never had an issue with metal shavings.
I only called you weird because you asked for it. I don't think anyone, ever has replaced a metal timing gear with a plastic one unless it's some high soot, carbon fiber belt drive system.
If I based my thoughts on double rollers off the pictures you posted then I would leery also, but not knowing what actually happened to the engine in question there could have been an engine failure that locked up the engine at high RPM causing the chain to snap.Yes, many people do upgrade to double roller but those scare me a little.
I get that you are probably not into the performance aspect of engine building and if a nylon gear works for you then go for it.
All good questions! Those roller chain examples above are 231 turbo V6 blocks running roller cams.
Why would anybody want to run a nylon toothed cam sprocket.
