I thought this thread would of died after the OP "decided" they didn't want to hang out with us. Need to invest in popcorn.
I have only seen one in person on my buddy's big block and all of the teeth were worn off, just one of many bad ideas GM had back then.GM chose the material, considering all the well-heeled knowledge here I'm surprised I'm the only one who knew?
this started out as an odd thread and it's...
I have an NOS chain/sprocket set. Nylon gears on the aluminum sprocket. It came in a box of parts I picked up in a "Lot". I would never recommend it unless you REALLY wanted to go full stock. I think it would be stupid as you couldn't hear the difference anyway. At least I never could. At minimum I would never use anything less than a good, quality single roller. Double is better, but for stock replacement...I've always used Hamburger's chain sets.I have only seen one in person on my buddy's big block and all of the teeth were worn off, just one of many bad ideas GM had back then.
On my buddy's big block when we first tore it apart and saw the came sprocket we both looked at each other like "WTF" the teeth we not broken but were actually worn down to little nubs then we were dumbfounded as to why GM would even do this and then to find out this was the trade off to reduce valve train noise it seemed like a bad joke.In case anyone has never seen a nylon cam gear in one piece and any other color than burnt orange...….here's what an NOS one looks like.
All I am saying is from a performance aspect a nylon toothed gear would never come up for consideration for any parts list.
so, not even your engine?
