i am trying to get my door pin input wired into my alarm and cant seem to get the right wire. does anyone know what wire and location for the correct one? :?
85 Cutlass Brougham said:You may have to use a relay to trip it because the pin switches are the positive side of the circuit on a GM car if I am not mistaken.
joe_padavano said:85 Cutlass Brougham said:You may have to use a relay to trip it because the pin switches are the positive side of the circuit on a GM car if I am not mistaken.
You are mistaken. The body that screws into the door post is the ground path. When you open the door, the single wire is connected to ground through the screw threads.
dan2286 said:joe_padavano said:85 Cutlass Brougham said:You may have to use a relay to trip it because the pin switches are the positive side of the circuit on a GM car if I am not mistaken.
Yes, it is ground.
85 Cutlass Brougham said:Mine has 2 wires on the pin switch, not one. Plus, the body is insulated from the switch, which I have already found odd. Also, when I removed it, the switch shorted and sparked when it touched. Maybe mine is an oddball. I took it all apart for the paint job so that I would not get overspray on the switch when I paint the jambs.
