OK, it definitely has an electric safety switch...
Like almost every older GM in the 70's and 80's, when the column rotates and moves the mechanical linkage, it also rotates a switch at the base of the column under the dash that opens a circuit when the car is in reverse or drive (consequently closes a circuit when it is in reverse for backup lights) - This is what the switch looks like :
and where it is located on the column
by hooking the shifter linkage up to the aftermarket shifter you will still get the neutral safety to work. You can unplug the two plugs, and use spade connectors slid into the two pigtails and hooked to the microswitches in your shifter to do the same thing without the original shift linkage. I did that in my 1980 C10 which had the same switch on the column.
the rotating collar on the column will mechanically lock the key from turning when not in neutral or park, but if youdisconnect the factory linkage, keep the column collar in park position, you will be able to turn the key all the time, and the electrical switches in the shifter will keep the neutral circuit from transferring power to the starter.
