new 406 pontiac finally finished
Wow, a 67' with a Torker. Staight outta the 60's man. And I see you did your homework, Pontiac 670 heads (and most all) max out at .450 lift any more just stresses the valve springs. Good build.
Did I miss the 670 part?
What are the rest of the cam specs?
Needs more carb.
I don't think you are going to be able to run pump gas.
More details needed, I don't want you to hurt the motor.
I was guessing stock 4 barrel heads. YC is a 2 or 4 barrel motor? Yeah, those closed chambers want high octane. EDIT- I'm seeing YC is a big car motor, 2 barrel, small valves, 10.5 comp. Any head work done?
I would think the carb would be good to 5600 or more. Flat tops and those heads = high comp.!
I like the poncho motor too. Gives people something to talk about 😛
G-Body_Vet said:
Have you ever thought about going with a properly setup q-jet? I think it would give you the best of both worlds.
heard the q-jet was the best ticket 😀 but know very little about them other than how take em off and put on my holley :lol: my spread bore holley has been on all my old circle track cars( limited late model, streetstock,superstock and open wheel modified) and it is really reliable I will see how it goes in feb for our first test and tune , the car should be up and running by the weekend
thanks
thank you did some studying . I love that 60's power, it had the 143 closed chamber heads i just freshened them up
Needs more carb.
still got a fuel sponsor from my circle track days got a 55 gal drum of 110 race fuel
left over from last race season, detonation will not be a problem :twisted:
cam specs
410021-12 .450 .450
267 277
213 223
112 Hyd. Hyd.
Hydraulic Flat Tappet Camshaft 1500-5800 Super low & mid-range torque. Excellent driveability.
motorholmes said:
Here's the real question:
What are all those Oregon hippies gonna think of that rowdy hot rod?
Oregon hippies? didnt know there were any left ! thought they all got hair cuts and drive echos
but that may be my bad :rofl:
