I'm on my 2nd new Brakebest select NMC11317Which master cylinder are you using?
I actually have a AC delco in route because I like to throw many at issues till it's fixed lol
Im not familiar with that part number. What's the application? What's the piston size?I'm on my 2nd new Brakebest select NMC11317
oh I'm not 100% sure on the piston size.. I ordered it as a 87 buick regal.. did the same for the AC delco but just expecting it to be a better quality?Im not familiar with that part number. What's the application? What's the piston size?
I found the 1" piston works best. I am using a master for a 1980 Buick Riviera with 4 wheel discs.
I will say when I bench bled the MC I pulled out the line that feeds the rear calipers and notice it had a weak flow?
The problem with bleeding the fronts first is that the piston for the rear wheels requires bottoming the pedal on the floor. You will not be able to get full travel and move that piston if you bleed the fronts first.Try bleeding the fronts see if that helps. I did the blazer/s10 brakes same problem turned out the front needed to be bleed first .
