Well, you may wish to fill in all of the missing data points in your original post. What engine is in the car, cam specs, heads, compression, etc. I know a fair amount about carbs, but I do not immediately recognize the carb number either, so it may be helpful if you posted what kind of carb it is. There are just too many carbs out there for most of us to know them all by list or model number ( I know the Holley 3310, 1850 and 4779, but that's about it off the top of my head) Is it a Holley? Carter? Edelbrock? Vacuum secondary? Double Pumper? etc. Plus, what gearing/trans/converter are in the car? What kind of carb did you remove, what ignition are you running, what linkage, is the TV cable geometry right, etc. Forum posting requires lots of detail as most of the time we do not know your car and can't see it. No part universally works for every engine or car, and knowing what you have goes a long way to telling us which direction to send you in. A helpful hint would be to tell you to write a description of your car/truck for your signature in your profile section, so that it prints up every time you make a post.
I will also add that if you replaced a Quadrajet with another 600 cfm carb on an otherwise stock 305, it won't make any real difference in performance unless your old one was not working right. In fact, you may lose off idle throttle response as compared to stock. If you did not hook the TV cable up with the right geometry, you can damage your transmission, and may also lose full throttle downshifts.
