Hi Everyone,
I now own an 87 Grand Prix Brougham, 305 V-8, with 63,000 original miles on it. I've done a little bit of work to it since I bought it such as repairing the A/C and swapping out some tires. I've also reinstalled the bolt that holds the dipstick tube in place. Is it common for these to fall out? Should I have loc tited it back in?
Also I have acquired a set of factory Rally Gauges from an '86 Grand Prix (also a V-8 car). I've done a little reading on here and it seems that all I need to do is run the negative wire from the tach to the distributor and change the sending units for the oil pressure and water temp and this thing will plug in and work? Is that correct?
If so where are these units located on the engine? And can I get them at a parts store or do I need to source them from a donor vehicle?
Last but not least. Is there any real performance gain on these small engines by installing the Monte Carlo SS dual exhaust? My tail pipe is falling off so I will need to do something soon.
Thanks!!!
Ron
Thanks!!!
Ron
