So the idea for my car was to originally make a clone of an FE3x. Since the kit is being sold, all I needed was to make a header panel. So I tried welding a euro panel, a calais front clip, and fiberglassing a whole new front out of foam/chicken wire and so far nothing's worked. So here's some info that I finally think is correct about the panel - this one
The concept car was made with the original '85 header panel. Then a front clip from a calais was used to rivet the plexi all the way across. Note that is not a euro panel, the guys who made it actually cut the panel to mount the side lights (orange turn lights) behind the plexi.
After failing on a donor header panel, I'm going to just plexi over the headlights like a drag car. Then cut out the center support of the header panel - top and bottom, and smooth out the bottom of the support straight across with fiberglass. I'll do the same for the top and follow the lines of the plexi in the picture above, with some mesh -- painted black. I'm keeping it simple this time, and will make a 'how to' whenever I get into it in a few weeks.
Ideas/input/ mesh grille tips please let me know
