I lifted the engine to replace the oil pan gasket and once the pan was pulled I found that the issue may be due to the pan itself. So I want to replace the pan and gasket.
From research I found that I want to use the blue Felpro 1 piece and the pan is the only thing determining if I need the thick or thin gasket. I can't seem to find out what pan I need though. Any help appreciated
Engine is a 350/383 in a swapped 87 LS, not sure what year or what it's out of. Dipstick is on the drivers side.
Thanks for any help....I WILL GET IT ON THE ROAD THIS YEAR! ( I hope)
