I had the same issue when i installed 1inch lowering springs from umi suspension. the back sits just right and front sits too high like I should have used 2inch lowering springs for the front .
You could try putting the car on ramps so you can safely get under it while the weight of the car is on the suspension. Then break loose the control arm bolts (2 lowers on each side and 2 upper nuts on each side) to see if the car will settle any more. Then tighten the bolts/nuts to spec. with the weight of the car on the front end. Since it sounds like none of the control arm bushings were replaced, I am less optimistic that this will change anything.No but I will try that.Please don't think I'm stupid but do I jack the car up and loosen them or is this something I can do with the wheels on.I looked at the upper and lower control arms and the nuts on both looked like they have not had a wrench on them in 37 years.
you can jack the car up and loosen them then set the car on the ground at full weight..once the car is on the ground tighten the bolts.
On a properly lowered car, this is not humanly possible. If it is, your car isn't low enough 😎
