get a sbo 307, 350, or 403
I say build as you go, but of couse there are many factors with this. For instance, do you live in a house or apartment? Are you in predicament where you can buy stuff as you go?
Reason I ask this, I did my swap in a hurry still ruffly 4 months latter car is not finish. It runs great and hard, but I work a full time car and my car is at my parents house and I only can work on it sometime. I got to a junk yard look around in every old car that came with a olds 350 or 403. The casting # you want is 399558, or 399558 2...these are sbo 350.
Also the reason I stated build as you go. You can do allot of things you might want to after you get the motor in the car. I say this due to I was in a rush installing my motor...trying to get it inspected(that's why I'm not driving it)
This is my cutlass motor installed
My swap was easier to a extent due to my car came with a sbo 307, and I pullem my motor complete with just about all the accessories. I say find you a block or complete motor and transmission at the junkyard. Get the major things for a tune up.
What i bought
Timing chain, oil pan gasket exhaust manifold gaskets, valve cover gaskets, oil for a oil change, oil filter, transmission fluid, water pump and timing change cover gaskets and a thermostat.
What i bought
