New to the forum!
1980 Lemans. 406. 700R4, 12 bolt.
"Clip Clop"
523 HP 527 TQ on dyno. Great street manners, and so far, mid 12's on the strip at 2200ft.
pump gas 10.5:1 Richmond Engines build.
Polyurethane engine / trans and suspension, Wilwood rear discs, 3:73 12 bolt.
new HID headlights, headliner, carpets, and custom 3000 watt stereo with 2-10" subs.
Black / blue pearl paint.
And some dumbass put a sunroof in it...
Welcome Scotty; I'm guessin' that you'll be 70 this year? You have put together my cousin car! As I also run a 406" SBC & had tried using a 700R-4. Run mid 12's & have a slopped rear window!. Of course your OE bumps were much nicer than mine. But now I'm on equal standing as I got rid of the big ugly chrome boat anchors. But the one thing that I noticed is you still have a V belt accessory set up. And I have a very nice V belt underdrive pulley set with belts that would fit your set up? These are cut from one piece of metal (billet if I spelled that correctly?). No run out , no flipped or tossed belts ever. Did I mentioned expensive? I ran these for many years, the crank pulley is 25% under drive & the water pump pulley is 8% underdrive. So together the water pump will be 33% under & the alternator & power steering will be at 25% under. The throttle response will be felt in the seat of your pants as they make a big difference. The down side is if you're in bumper to bumper traffic (think Power Tour) & the air temp is 97* for 3 hours they may not pump enough coolant to keep every thing cool. I seen temps reach 210* & was shutting off the engine & re starting often as 210 is as high as I want to see. Hence that's why I replaced them with 10% underdrive units & these are for sale with like new belts. The inside groove on the crank pulley is for AC. And they fit a long pump setup. If you're interested let me know. And again welcome, Ole' Bob.
Reactions: Injectedcutty
New here, and i was wondering if i can still use my original wire harness and computer with the vortec engine from 98 chevy truck, i will be swapping it to carb, since it has the hole for the mechanical fuel pump and push rod, any help will be much appreciated
Swapping into 86 monte carlo ss
