New to the Malibu scene.
Thanks guys. So is it just the 5 bolts and it pulls right out? (Excluding the speedo cable I'm guessing)
You'll still have to remove the bezel, or gauge surround first. You'll find small black screws around it, and three right over the speedometer lens. Also the wire going to the cigarette lighter. Once the front of the cluster is removed, then there's the five nuts that hold the pod on. Then once the pod is pulled away from the dash, unhook the speedo cable...and be sure to unhook the small cable for the shift indicator. You'll see a small clip attached to the column sleeve...unhook that from the sleeve. If there's any problems, give us a shout out.
Reactions: PraeT
