oldmansmonte said:dixon_ronald said:Yes ditto, what other options can be considered in staying with the same motor setup? A few questions...Are you running larger injectors than stock? Have you contemplated having your ecm reprogrammed? I am running a rebuilt 350 tbi in my monte for some of the same reasons you are. But now I am thinking of going witha 383 stroker and changing to the aforementioned items (injectors and ecm changes).
I'm quite familiar with TBIchips.com. Brian is kind of a dick. The only advice I didn't follow of his was a better fuel pump. I have a new Delphi pump for a 350 truck, but a higher performance Wahlboro or something similar Im sure would land me more power. What I do have is a machined 46mm TBI, 65lb flow matched cop car injectors, ECM from a 92 c/k 350 with a custom dyno tune. Adjustable FPR, Flo-tec headers and full 2.5 exhaust. I wouldn't recommend putting a 383 on a TBI system. I don't care what Brian says, its not going to work right and you're going to leave tons of power on the table. And possibly run it lean and melt the cylinder walls. The stars, moon and planets would all have to align twice for that setup to work.
If you're interested in modifying your current setup for some more power, I have a Holley 50mm TBI brand new I never installed just sitting around. Or when I remove my current setup I would sell you the whole thing together. GMPP Aluminum Vortec intake with the machined TBI and FPR all installed. It would definitely be a power upgrade from your current setup but a tune would be ideal to go with it.
Yes I am looking into improving on what i have so I will give a look into your setup. Let me know when you have it available. Thanks!
