Ok have a 350 chevy Monte Carlo ss the engine is different from the vehicle. Having issues starting it. Changed the pump. Still can't get gas to the carb. Put a syphon pump on the feed line and pump out to look like some bad gas it was black. Pumped the gas tank out put more in pumped till I was able to see clear fluid. Still nothing. Put carb cleaner got it turn over start then shut off. Have no clue what it could be was thinking vapor lock maybe but idk. Can't find a decent mechanic that knows what they are doing with a older vehicle so idk was thinking maybe I didn't install the pin correctly so it's not sitting on the shaft of the pump. I'm praying it's not the cam lobe or anything crazy. Thought about putting a gas can and gravity feeding the carb. But it won't help the issue so idk any observations or anything I'm missing any help would be appreciated.
Pss. It was running then stopped and wouldn't start so then I started the process with changing fuel pump etc.
