Okay, my car came into my ownership with the brake light on the dash on.
I replaced the rotors and pads in the front because they were warped.
I refilled the master and my rear brake line started leaking SO... I replaced the rear brake line.
Now the pedal goes to the floor, I can still stop its just spongey, the master is good and I have no leaks anywhere else.
The brake light on the dash is still ON! and I have no brake fluid in rear when bled.
So, what is this brake check valve or proportioning* valve I keep hearing about? It shuts the rear off with loss of pressure? How can I reset it and where is it located?! Thanks
