no fire
So the pick up coil was the reason for the rebuild on the distributor...
Unplug the four wire connector that goes from the distributor into the wiring harness on the passenger side. This is the ESC connector, with it unplugged check and see if you have spark...does it?
Also are you checking more than one plug wire? and what kind of spark tester do you have?
yes that was the reason for the rebuild i unplugged it just like you said still didnt make a diffrence and im not using a tester im pulling the plugs and lookin for the arch
Make sure you are setting the plug against a good clean ground, if not you may be chasing your tail. I mean clean ground no paint. If you have a small piece of wire run it from the threads of the plug over to the battery ground or the brake lines are usually a good ground.
This should help...
