no fire
So lets recap....
It quit running, no spark was the diagnosis
You checked it out, bad pick up coil in the distributor. Pulled the distributor, replaced everything. Cap, rotor, module, pick up coil. Still no spark...
Where are these parts from? Are they good / better / best as far as quality?
Depending on what quality of parts you used I feel at this point you have a bad part. I would try putting the old module back in it. I have seen lots of (autozone / o' reily / pep boys ) aftermarket parts be junk right out of the box. I would make damn sure they are all good.
well all parts are new except the ignotion moduel i had it tested before idid the pick up and the test showed it good
get another distributor from a running engine and try that...get one from a recycling yard if need be
