2000.malibu.ls said:
custom442 said:
Well it's not necessarily too much carb, it sounds like your secondaries are slow to open, which means it could be a tune problem.
Does this happen: when in first gear, you smash the pedal to the floor and it lags then starts to pick up slowly?
yes? tuning problem?
First tune the carb so it's idling nicely, has the ideal idle mixture (which you can test with a vacuum gauge, google for more info), and set your floats at the optimum level if needed.
Make sure you have a good vacuum connected to your secondaries, and it sounds like you need to tune the secondaries to open sooner. This you have to tune by driving and testing (it’s recommended to test in high gear), because they are supposed to only open under a load when you mash the pedal to the floor. Vacuum secondaries open at different rates with different diaphragm springs inside. Lighter springs = open sooner, stiffer springs = open later. What you’re lookin for is a spring that makes your secondaries open a tad late after you step on it and ease into the extra power. You shouldn’t feel a jump with vacuum sec. Google around to find some instructions or kits with different sized springs. It wouldn’t hurt to call edelbrock and get their advice also.
There are also tricks you can do to find out if your secondaries are opening, google and see if you can find some
It also sounds like your power valve could be opening too late. You’ll need a vacuum gauge to test this and buy the correct valve.
Here’s a test you can try to make sure your power valve is working – turn the idle mixture screws in all the way at idle and if it sputters and dies then the power valve is working.
I agree 750 cfm is kinda big, but it can fit just about any engine if tuned properly. You might also look into jet sizing. But you don’t need a new carb, just spend some time and work tuning, go check out a book on tuning carbs at the library.
