When I cycle the key on to start the car, none of the warning lights come on on the dash. It is a 1986 Olds Cutlass salon. I've also noticed that the TCC does not lock up correctly. Every now and then it'll momentarily lock up after 45 mph but within 3 seconds it unlocks and then that's it. At about 70 mph it'll lock up for a little bit longer duration of time and then cycles. I'm curious to see if anybody else has had the same issue with the warning lights coming on in May of had a ECM failure or something like that.
