Front end lift is a huge issue with most street cars designed before 2000 or so. Auto makers didn't think anyone needed to go 150 mph. Overdrive gears were weak and would break if you ran a car that fast for any length of time. 1990's/early 2000's C5 Corvettes, Mustangs, Trans ams, etc.... you name it, take them up to 165 mph and they will top out the springs.
Covering the upper grills on the 2+2 makes a bunch of downforce and makes the nose slghty lower at 165 than it is at rest, while the radiator support air dam keeps the motor @ 180 degrees.
I'm going about 165mph in these pictures:
You can tell how fast I'm going by how far the windows are blown out. They don't come off the seals until 140.
Here is a typical Mustang at the same speed trap going only 150mph:
and late 1990's Cobra:
And 4th gen F-body with a taped up nose:
None of these cars are accelerating, This is towards the end of a long straight and if anything, they are decelerating.
C5 corvette noses are higher than any of these above 160 mph.
Here is a Tom Whalen's C5-Z06:
Tom set the Overall Record at the Big Bend Open Road race in 2015, but when I originally showed him this picture back in 2008, he freaked out. He had no idea he was topping out the suspension @ 160 mph (at rest, the car is SLAMMED). He blocked off the grills and added an extractor hood and now it goes over 210 mph.
