Ok, I have been all over this board post things I need help with. I have finished a lot. Although, now I need help with the worse thing of the whole project. PAINT!!!!!
The car has been a outside car for a number of years. The paint shows it. There is surface rust and the vynal roof has been removed and not completed. There is some rust in between the frt and 1/4 window and the 1/4 window to the back. I have an advantage at the dealership I work at that I can have someone do it on the side.
My concern is that the car will be kept outside year round. It is a cruiser, not a show car. I need some help with the options that I have. I wanted to do the "flat black" thing with the stock color on the bottom half but, I found that I have some rust and dents below the belt line.
When I bought the car I was going to go with a what a couple friends have done which is use DP90 and prime/seal it with that. Then just drive it. But, the problem that I didnt know is that the vehicles they are working on and cruising spend most of their life in a garage. Mine will not. The problem is that the flat dp90 "grays" out over time due to not having a UV protector in it.
So next idea, fix the rust and body work and prime as needed then spray the car with a single stage black flat. I have found 3 of those such products. (Simm's hot rod black, ppg rat rod black etc)
I am hoping someone will come one here and tell me a magic product that can be used and will be affordable.
Once again, cruiser not a show car but a car that is show-able. (I know what a tool)
Any advice?
Any advice?
