OBD1 Live Data Scanner Reccomendations?
MrSony
6,965
7,092
Des Moines, Iowa
Ive been searching and haven't come up with much other than that expensive bluetooth thing or WinALDL.
Any reccomendations?
Reactions: fleming442
And check your grounds.
Im sure there is corrosion and rust built up on that computer harness
why not check the fuel pressure first before you spend money on something you may not need
If you have an ECM or ECU whatever with OBD1 or 2, eventually you'll need one sooner or later. It's not our money we're spending, so it's all good! 🙂
The scaner below I recommend highly for a OBD1 and I will tell you why and its made by Actron/Sunpro.
Working at the dealer we had OTC scanners it was ok but wasn't impressed and not user friendly and exspencive.
I did like the Snap on scanner but exspenive but I wanted one so I asked rep for Snap On that came to our dealer to order one for me, his response was save your money and wait for the Actron scanners to hit the stores soon. I thought this guy was high on drugs when he said that. So I asked him whats so special about this scanner, he told me that one of the engineers that took part of developing the OTC scanner left the company and works for Actron/Sunpro and developed a OBD1 scanner and its just as good or better than a OTC and Snap On scanner.
So I waited till it hit the stores and purchased one and it came with two GM cartridges, OBD1 and 94-95 OBD2 , Ford OBD1 cartridge and all the cables. At that time I paid $400 for it. I was very impressed and user friendly worth the money and live data.
Model number, Actron cp 9110
You can try Ebay and make sure that it works.
