oem water pump
torque455
14
Ok i have had problems with my 1776 flow kooler water pump since i got it ...it wit not work with my stock 3 groove pulley with out spacing it out a lot ...and that for me has always caused me a wobble....so i am looking for what would be the sock oem part for a 1976 delta 88 455....i want it to bought from a store like autozone..advance auto...napa etc...not ordered from the net....on the flow kooler i have the pulley will hit the pump before it is seated on the shaft......i want the correct pump with no shimming/spacing problems etc...i want to bolt it on and go...i guess the 3 groove would mean its for a car with a/c.please if u could post for me a part number and retailer...the only thing i can seem to find is .....
autocraft pump from autozone...here is the p/n and info ...you can look at it on autozones site and tell me what u think
------>Part Number: L58-297H
Weight: 11.16 lbs
Warranty: 1 YR
Application: Single outlet<---this is nice b/c im not running a/c but wana use stock pulley...and wont have to worry about getting a plug or tapping and putting a bolt in it
With A/C
Notes: Optional severe duty pump :wink:
DrRansom442
858
2
St Charles Missouri
car_nutter
n00b
Apr 9, 2009
FlowKooler Hi Flow Water pump for Olds 455
Sounds like you should have bought the 1775 if you had to space it out. It is 6".
