Ok i have had problems with my 1776 flow kooler water pump since i got it ...it wit not work with my stock 3 groove pulley with out spacing it out a lot ...and that for me has always caused me a wobble....so i am looking for what would be the sock oem part for a 1976 delta 88 455....i want it to bought from a store like autozone..advance auto...napa etc...not ordered from the net....on the flow kooler i have the pulley will hit the pump before it is seated on the shaft......i want the correct pump with no shimming/spacing problems etc...i want to bolt it on and go...i guess the 3 groove would mean its for a car with a/c.please if u could post for me a part number and retailer...the only thing i can seem to find is .....
autocraft pump from autozone...here is the p/n and info ...you can look at it on autozones site and tell me what u think
------>Part Number: L58-297H
Weight: 11.16 lbs
Warranty: 1 YR
Application: Single outlet<---this is nice b/c im not running a/c but wana use stock pulley...and wont have to worry about getting a plug or tapping and putting a bolt in it
With A/C
Notes: Optional severe duty pump :wink:
Weight: 11.16 lbs
Warranty: 1 YR
With A/C
